1 or 2 rears?
Discussion in 'Home Cinema Speakers' started by planbeta, Jun 26, 2002.
  1. planbeta
    planbeta
    May 20, 2002
    16
    Stourbridge
    I've decided to go for 6.1 setup, but don't know whether to go for 2 rear speakers or just the 1?
    Is there much advantage of having 2 rears over 1?
    Thanks! :clown:
  2. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    Use two myself, placed as close together as possible and angled down towards the listening position. I´ve tried one, two, monopoles, quadrapoles, a centre speaker and the two monopoles give me the best results.
    It may be a different case for you and your setup though.
  3. planbeta
    planbeta
    May 20, 2002
    16
    Stourbridge
    You mention that you angle your rears downwards, how high do you have these positioned?
    Come to think of it I have no idea at what height to position any of my speakers when I get them?!?! :confused:
  4. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    My side dipoles are about 1 - 2ft above my head and the surround backs about 2-3ft above and about 3-4 ft behind me.
    Others have all their surround speakers at the same height but its down to personal taste in the end really.
  5. bob007
    bob007
    I have my two surrounds 2ft above ear level when sat, only use 1 surround back, this is a little higher, 5ft behind and pointing down.
  6. planbeta
    planbeta
    May 20, 2002
    16
    Stourbridge
    Thanks :cool:
    Just been reading some info at dolby.co.uk - they also suggest placing the surrounds at 2 feet above ear level.
    I think like you I will place my rears a little higher to get a tad more distance, as my sofa is quite close to the rear wall!
    Cheers :)
  7. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    692
    London, UK.
    +38
    Will there be any noticeable tonal difference if the rear-back speakers are placed higher than the rear-side speakers?
    I'm also wondering how to position them.
    Thanks.
  8. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    If they are the same speakers then there should´nt be any difference. If there is, its likely to be minimal.
  9. stranger
    stranger
    does one c/back mission 77ds bipole equal two d/ radiating? (approx)
  10. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    I suppose you could look at it that way, except the bipole will be firing left & right and the direct radiators firing forward.
