1 GIG SD Card £17.99 !!
Discussion in 'Photography Forums' started by sanjuro, Mar 21, 2006.
  1. sanjuro
    sanjuro
    Jun 30, 2003
    168
    2
    +5
  2. beachy
    beachy
    Oct 20, 2005
    1,319
    48
    +62
  3. stu1wyatt
    stu1wyatt
    Sep 3, 2005
    507
    28
    +50
    7 day shop are rubbish imo, I ordered an Ixus 500 from them around 2 years ago and they hide the fact you need to pay duty on these things
  4. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    7dayshop are brilliant and I use them all the time. The website CLEARLY tells you about duty :lesson:
    I've got a Viking Sd card and it appears to work perfectly in my Z2.
  5. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +59
    By bizarre coincidence my father has just called me complaining about his Viking SD card obtained from 7dayshop, which has failed after less than 4 months of use. That said, I'm pretty sure it's under warranty so he's going to contact them to see what they say.
  6. beachy
    beachy
    Oct 20, 2005
    1,319
    48
    +62
    yes i've read some bad reviews on them at the amazon website (i think) it does seem very cheap for a 1gig card, maybe it's just a case of you get what you pay for. :(
  7. colinwheeler
    colinwheeler
    Jul 12, 2005
    2,423
    Basel
    +153
    Saying that they are down in the 20s of Amazon.co.uk now. The Viking cards are fine. I use the 1Gb ones all the time in my IXUS 750.
  8. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    AVforums doesn't do that well in their ratings either apparently, not worth the paper it's printed on to be honest :laugh:
  9. Magslad
    Magslad
    Apr 22, 2005
    994
    46
    South Bucks, UK
    +143
    I've got two Viking 1GB SD cards (bought from ebuyer) that I use in my D50 - I've never had any problems with them and write speed is also fine (I bought two as they were so cheap in case one did fail, but no problems at all so far).
    Incidentally, although they are badged 'Viking' the cards I have are actually manufactured by Toshiba. Not sure whether this would always be the case (don't know whether Viking just buy job lots from whatever manufacturer happens to be offering the best price at the time, then re-sticker them), but the cheap price doesn't necessarily mean poor quality.
  10. kbfern
    kbfern
    Aug 17, 2002
    17,929
    Wolverhampton
    +6,093
    I ordered 2 viking 1gb sd cards yesterday from Amazon @ £22.16 inc p&p.I currently use a 512mb viking in my Panny Z5 and it works fine (had the card for a year now).
  11. beachy
    beachy
    Oct 20, 2005
    1,319
    48
    +62
    might be worth a go then, i just bought a sandisk 512 ultra 2 from picstop £27.40, ordered it 10.30am tuesday arrived 12 noon yesterday, really impressed with the speed of delivery bearing in mind their based in isle of man, and the post here in milton keynes is normally crap ! :D
