1 Audio source to 2 amps
Discussion in 'AV Receivers & Amplifiers' started by demon9k, Jul 17, 2005.
  1. demon9k
    demon9k
    Feb 6, 2005
    2
    Hi everyone! :hiya:
    I was wondering if anyone has got advice on taking 1 audio source, from my PC (mini jack to 2 RCA), and making it go into both my Hi Fi amp and home cinema amp. I had a look at the TS20 (http://www.qed.co.uk/acc/ts20.html) but I wasn't sure if this was exactly what I want because the description of how it works is a bit vague. The PC and both amps are within 3 metres of each other.
    Any advice would be greatly appreciated.
    Paul
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Easier and cheaper to just get another sound card. Then you can send different sounds to different amps!!!
  3. Graham_E
    Graham_E
    Nov 8, 2004
    162
    +10
    use the tape lop on your amp - put pc into tape in, and run tape ut to the HC amp.
    Job done!
