Master,
Any speaker cable will only make the sound worse. Thicker speaker cable will make the sound less worse.
If you stay away from the brand name cables, then the price of 2.5mm^2 is very reasonable - wire is actually pretty cheap if you dont have to pay for the advertising as well.
Some of the ebay cable has had a higher resistance when tested than would be expected, the implication being that the quality of the copper isn't as pure as it could be. Even so, ebay 2.5mm^2 with Chinese copper is still better than brand name 1.5mm^2.
If you want a known quantity, generic 2.5mm^2 cable, try
79 Strand Twin Fig 8 Speaker Cable
Very similar to QED 79 strand, which was the benchmark speaker cable before cable manufacturers discovered marketing departments. This cable has been tested by a forum member, and found to be of good quality.
There are 'rule of thumb' calculations that look at total cable resistance as a % of speaker load resistance, but I wouldn't bother fiddling about. Buy the thicker cable.
Andy.
