1/4 HD vs. XGA
Discussion in 'Projectors, Screens & Video Processors' started by dunkyboy, May 14, 2003.
  1. dunkyboy
    dunkyboy
    Jun 5, 2002
    633
    London
    +6
    Has anyone gone from an XGA (1024x768) 4:3 projector to a 16:9 1/4 HD (960x540) projector, or made a direct comparison to the two? Can you tell me if the drop in resolution is a big deal, in your opinion? Particularly with PAL DVDs, as you lose 36 lines of vertical res. off the PAL standard. :(
    FYI I'm thinking of upgrading from an XGA business PJ to a Panny AE-300.
    [Note: I'm running it off an HTPC in case that makes a difference.]
    Cheers,
    Dunc
  2. beta
    beta
    its a good question
    for straight DVD I dont think theres any difference.
    I guess it comes down to how much PC and hidef stuff you want to use.
    Some say the HD looks better on the lower res 1/4HD as scaling is smpler and smoother, my personal, and I stress personal view is it looks nicer on my hs10 as you see some more detail with the extra panel.
    I guess all you have to do is see them both and make up your own mind.:lesson:
  3. dunkyboy
    dunkyboy
    Jun 5, 2002
    633
    London
    +6
    Mm, it's almost entirely for DVD. But even so... I'm a bit reluctant to spend £1500 on something that's going to lose resolution on PAL DVDs... :(
    Dunc
  4. beta
    beta
    sounds like you have made up your own mind
  5. dunkyboy
    dunkyboy
    Jun 5, 2002
    633
    London
    +6
    Actually, yeah - I've got a buyer lined up for my PJ and if it goes through I'm getting m'self a Panny AE300, believe it or not. :) I expect I won't mind the slightly lower res, but I still don't like the thought. Obviously if I could afford an HS10 I'd go for one, but that's a good £600 dearer, and I just can't justify it (nor could I live without a PJ long enough to save up for it! :blush:)
    Dunc
