1:1 pixel mapping - important for gaming?
lance.carter
i think it's all in the title. I am not buying a tele for films, but for better gaming.....do i really have to be concerned about 1:1 pixel mapping?
I'm already appreciating that a fast response time is ideal but what else should i look for when the tv is primarily going to be used for PS3 and standard def TV (for the foreseeable).
Cheers...
Lance
MikeKay1976
very important for PC gaming, and xbox360 gaming if you plan on using the vga cable.
if you dont plan on using a vga cable for the 360 and you never plan on pc gaming then it doesnt matter.
MikeKay1976
So it is a must for PC gaming?
well..... its not a MUST, i could play pc games on my wlt66 but it only looked good at 1024x768 in 4:3 picture mode.
for gaming higher the resolution the better, and playing at a 4:3 image is wasting a 3rd of the screen.
there are plenty of sets capable of doing 1:1 mapping now, so, if pc gaming is an issue and you have yet to purchase, then i think the question should be why NOT get a set with 1:1 mapping. :)
