1:1 pixel map
Discussion in 'Projectors, Screens & Video Processors' started by coastersteve, Dec 1, 2003.
  1. coastersteve
    coastersteve
    Jan 7, 2003
    64
    +3
    Could someone point me in the right direction howto do 1:1 pixel mapping from PC?
    Is this simply if your projector is 800x600 should the PC be set to the same resolution or is there more to it?
    Thanks in advance.
    Steve
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    There's a link in the Projector FAQ thread that gives a lot of info about this. Way above my head tho :(
    HTH :)
  3. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Yip, that's it....................... it just gets a little more complicated if your projector has a non standard resolution - like the AE100/AE200 (856x484 - plenty of instructions on the forum how to do this) or HS10/HS20/HT11/12 - 1366x768) then you need a program called Powerstrip which allows you to set non-standard or custom resolutions - also plenty of instructions in posts on how to use this program - do a search. If you want to do custom resolutions, you need to have a graphics card which will support them - most hcpc folk go for Radeons, some nVidia's have issues, tho' I've no personal experience of using them.
    Sean G.
