02 Voicemail
Discussion in 'Mobile Phones Forum' started by hunkiemunkey, Apr 22, 2003.
  1. hunkiemunkey
    hunkiemunkey
    Jul 17, 2002
    88
    I have had an 02 pay & go mobile for about 2 years now, throughout this time I have had voicemail turned off.
    For some reason 02 have now switched it on, and I can't get rid of it
    Has this happened to anybody else? And if so, did they manage to turn of the service?
    Thanks,
    John :mad:
  2. gobblit
    gobblit
    when they were bt 1750 used to turn the answering service on 1760 used to turn it off not sure if it will still work and cant remember if it works with pre pay but you can give it a go
  3. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    Just had a leaflet through in the post from O2 and remembered this thread...
    According to what I've just been sent, it's still the same as it used to be...
    Turn Voicemail on/off: 1750/1760
    K. :)
  4. a1bert
    a1bert
    Voicemail is a right pain - especially if you have to pay to retreive your messages!!!
    I tried the 1750/1760 - but it doesn't give the option to 'turn off' voicemail (Nokia3310/5510)
    I found that you had to 'turn off all call diverts' - it's in the menu system somewhere, can't look coz I don't have nokia's anymore.
    Hope this helps :)
