wormvortex
The problem is either an Openreach issue before the DSLAM in the green box in the street or a talk talk issue. Either way another call to talk talk is required and you need to explain what you've said here that you have 18mbps sync/connection speed reported in the router stats but when you go on a speediest website then it is only reporting 0.2mbps. It could be any number of things causing it from something as simple as a cap placed on the line right up to a faulty piece of equipment somewhere beyond the local network. They will either look at it their end or send another Openreach engineer and if they do again explain all this to them.
The socket is fine now that you've cut back on the cabling in the socket.
