¿Panasonic TH42PA30E or Sony KE42TS2E?
Discussion in 'Panasonic TVs Forum' started by MARTOLA, Sep 15, 2004.
  1. MARTOLA
    MARTOLA
    Please, I have to make a decission asap!!!!
    Thanks!!!
  2. Orlando
    Orlando
    Feb 2, 2004
    158
    Essex
    +5
    You will be edged towards the Panny on this site.
    However I think the Sony has a sharper, brighter picture at the expense of crushed blacks. The Sony is also much more expensive and the picture can sometimes struggle with fast movement.
    I have the Panny myself, but would have no qualms about having the Sony. I didn't buy it as it was relatively new out when I was looking and it was a bit of an unknown quantity.
    They are both top tele's, try and view then both together and decide what you like best.
  3. MARTOLA
    MARTOLA
    I forgot to tell you that I can buy both TV´s at the same price. Wich one should I buy? I think that the Sony is the best choice due to its resolution (1024x1024) but I haven´t read much about it. I have read very good reviews about the Panasonic so I do not one what to choose.
    Thanks in advance!!!
  4. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Don't just assume that bigger numbers means better. The Sony screen is interlaced unlike the progressive panel on the Panny. This may be a disadvantage to you. Do a search for Alis and make up your own mind. There was a good post recently about Alis in the topic comparing a Panny with a Hitachi.
    -Ian
  5. MARTOLA
    MARTOLA
    So you think that the Panny is the best option? I am very confused because nobody tells me the same thing. I thought that the most important thing was resolution, but after reading about ALIS I am a bit dissapointed. If someone else agrees that the Panny is the best option I will go and get it!!!
  6. Elvis
    Elvis
    Get the Panny
