£899 42" Samsung Plasma
Discussion in 'Samsung TVs Forum' started by Degas, Jul 27, 2005.
  1. Degas
    Degas
    Aug 29, 2004
    191
    My apologise if this has already been posted but I thought it may be of intrest to some, eBuyer currently have a 42" plasma up for £899 + stand and speakers with the option to buy a DivX DVD player for only £1 extra, link here:-
    LINKY
    The specs are as follows:-
    * Brand:Hisense
    * Model:pDP4211EU
    * Descriptions:42 inch PLASMA color TV
    * Display Size:42 inch(106cm) diagonal 16:9
    * TV RF System:DK/I/BG/L/L'
    * TV Colour System:RF: PAL SECAM AV: PAL/NTSC/SECAM
    * Channel Coverage:200
    * TXT:10 Pages For European Languages
    * Stereo/AV:NICAM A2/SCART
    * TUNER:Built-in Tuner Volatage synchronized
    * Audio / Speakers:20 Watts(2~10W)
    * Voltage:120V-240V 50/60Hz 3-prong polarized plug
    * AV input:1 AV Input; 1 S-terminal input; 1 Y Cb Cr/Y Pb Pr mux input.
    * Graphic input:1 analog RGB D-SUB 15pin input
    * Audio input:1 AV audio; 1 PC audio
    * OSD:English German French Spanish Italian
    * Pixel Pitch:Horizontal 1.095 x Vertical 1.110 mm
    * Display Pixels:Horizontal 852 x Vertical 480 Pixels(1Pixel=1 R,G,B cells)
    * Pixel Pitch (mm):0.297 x 0.297
    * Pixel Type:R,G,B Stripe
    * Effective Display Size:Horizontal 932.94 mm x Vertical 532.8 mm [36.73 inch(H) x 20.98 inch(V)]
    * Number of Colors:16.77 milion colors
    * Peak Brightness:Typical 1000 cd/‡u
    * Contrast Ratio(in dark room):Typical 3000:1
    * Viewing Angle:Over 160‹
    * Power Consumption (W):420W
    * Panel maker:Samsung SDI V3
    So then, any thoughts?
