£800 TO spend on amp+speakers
Discussion in 'Home Cinema Speakers' started by pokerdon, Mar 22, 2006.
  1. pokerdon
    pokerdon
    hi all .
    thanks for any help i've got a £2000 wad of cash to spunk on a new set up. i'm def getting the pjtx200 cost £1189.99 free del and three yrs warranty.. so i got £800 left.
    the m35i floor standing speakers look nice and i bet they sound better (no need for a sub ((maybe add one at a later stage along with two rears and a centre).
    is this a good choice to start with and then build on by adding the above .i've looked at all in one speaker sets all day and its doing my nut in they all look well small and the subs are even smaller..
    i want to listen to music as well so i think this type of box is best.
    i can get them for £299 so ive got £500 for an amp.. any ideas as i haven’t got a clue.
    pref 6.1..optical in and all that (looked at some demons) can you get them with dab???
  2. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    pixmania are doing that projector for just under a grand, but I assume that's just with a 1 year warranty. I'd check what's covered on the warranty though, cause bulbs won't be included, how many dead pixels etc.
  3. pokerdon
    pokerdon
    yes i'll ask for a pixel check. befor they send it .:smashin:
    any one know were to get a top notch amp for £500 then....:D
  4. pokerdon
    pokerdon
    NOT GETTING ANY HELP TODAY THEN. LOOKS LIKE ON ME OWN
    NEVER MIND THANKS ALL THE SAME THOUGH....
    :hiya: :suicide:
  5. pixelpidgeon
    pixelpidgeon
    May 5, 2005
    3,552
    +1,785
    Hi. Have you had a look in the speaker powerbuy section. I went for the SVS cinema package. Very clear cinema sound. nd very good build quality too. im no expert, but i think you could do alot worse for the money. Next day delivery if ordered early enough too.!
