dodgydaz
Established Member
Dont usually like to write these types of post but I need some advice from you guys....
I am after a decentish lappy for £600 or under to replace my noisy but reliable HP Pavillion.
Ideally I would like 2gb of RAM, 15 inch screen and a fast SATA hard drive (poss - 7200rpm).
Thats it really. As its going to have Vista installed I want the best spec possible for my budget that is going to work well with Vista.
