£500 ish to spend on my 1st cam - help!
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by a5h, Jul 21, 2002.
  1. a5h
    a5h
    Jul 21, 2002
    365
    +8
    I'm looking into buying my first cam, I'm considering the JVC GR-DVL 367 as this has SD memory and will take XGA & VGA stills, also has DV in/out,.
    I basically want a decent cam that will take reasonable stills aswell, any advice or suggestions as to what to buy etc or info on owning the JVC are really appreciated.
    PLEASE HELP A NOVICE!!
    Cheers,
    ASH
  2. Drafter
    Drafter
    Be careful of JVC I've had nothing but trouble with mine. See my other posts.
    Drafter
