£500.00 upgrade required
Discussion in 'Subwoofers' started by megson, Jun 3, 2008.
  1. megson
    megson
    May 13, 2003
    323
    28
    Tipton
    +77
    I have an M&K K12(SF) sub with my M&K Xenons in a small dedicated garage conversion.
    For about £500.00 (could go a tad higher!), could anyone suggest a sub that would be a significant upgrade - not necessarily M&K.
    Help and suggestions would be appreciated.
    Regards
    Megson
  2. megson
    megson
    May 13, 2003
    323
    28
    Tipton
    +77
    Opinions really would be welcomed and appreciated.
    Megson
  3. hoppaz
    hoppaz
    Oct 1, 2005
    1,916
    +225
    Hi Megson,
    I googled your sub but struggled to find any info. Can you post the specs (size, amp power, frequency response)?
    If you do you might get a better response.
    Hoppaz
  4. megson
    megson
    May 13, 2003
    323
    28
    Tipton
    +77
    Hoppaz
    Its the M&K KX12. A sealed box enclosure with a single 12" super fast driver. Power rating is 150 watts RMS with a frequency response 20Hz - 200Hz. Dimensions (HxWxD) = 15" x 15" x 17". Weight is 20.4 Kg. I paid £600.00 for it about 18 months ago.
    M&K subs are generally highly regarded and I know M&K profess that the power wattage quoted is misleading and the subs punch well above their weight.
    I understand that a better sub will improve the performance of my xenon speakers.
    Megson
  5. stevefish69
    stevefish69
    Jun 25, 2004
    4,242
    +458
    You could pick up a second hand SVS PC+ or old Ultra if you are lucky for that price.
  6. hoppaz
    hoppaz
    Oct 1, 2005
    1,916
    +225
    You could possibly look at second hand as Stevefish69 suggests. SVS make great subs and the one's he suggests should outperform the M&K KX12 even if it has a bigger driver (15").
  7. Peter Galbavy
    Peter Galbavy
    Dunno if this matches the requirement, but as a Monolith owner I can recommend it without hesitation. Plenty of other threads on here about it. £430 odd delivered AFAICR.
  8. nictry
    nictry
    Apr 28, 2002
    5,820
    Kent
    +649
    How about a B&W ASW675? I love mine and you should be able to pick one up second hand for around £450 :D
