£400 to spend?
Discussion in 'AV Receivers & Amplifiers' started by bazzae123, Aug 23, 2003.
  1. bazzae123
    bazzae123
    Mar 10, 2002
    315
    16
    I'm looking for a receiver/speaker set-up to go with my new TV. My budget is £400. The components I need to connect are a DVD with internal 5.1/DTS, a CD player. Any recommendations would be greatly appreciated.
    Bazza
  2. Sunday Ironfoot
    Sunday Ironfoot
    You'd struggle to get a separates system for £400, you may have to consider an all-in-one system. Could you perhaps stretch your budget a little?
  3. Sunday Ironfoot
    Sunday Ironfoot
    You could buy a Marantz SR4300 for £200 from Richer Sounds:
    http://www.richersounds.com/index.php?f=itemdetl.php&p=300197
    And for maybe an extra £300 you could sqeeze in a decent surround speaker system with cables. Someone else from the speakers section could prehaps recommend some speakers for you.
  4. Sunday Ironfoot
    Sunday Ironfoot
  5. bazzae123
    bazzae123
    Mar 10, 2002
    315
    16
    Thanks M8,
    Bazza
  6. luv ya jen
    luv ya jen
    fs1 totally rock
