£400 to spend on a widescreen
Discussion in 'General TV Discussions Forum' started by Al Naz, Oct 2, 2004.
  1. Al Naz
    Al Naz
    Sep 29, 2004
    71
    9
    Hi All looking to get a wide screen 28"TV to replace my old toshiba 25", i have only £400 so i am torn between these 2
    Panasonic TX28DTX1C
    Jvc AV28X4S
    Both from Empire direct i am edging towards the JVC as it seems to have a better spec but if any one can offer any advice it would be much appreciated
    Cheers NAZ
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Naz,
    Seeing is believing! :lesson:
    Comparing the specs is a good place to start, particularly if you have a requirement for a certain number of scarts etc.
    However, nothing beats a side- by- side comparison in a shop. :lesson:
    Even if you are going to buy on the web for the cheapest price, see if you can get a demo somewhere (but don't say TG put you up to it! :laugh: ).
    Good luck. :thumbsup:
