£400 to spend on a sub...
Discussion in 'Subwoofers' started by liamjf, Sep 15, 2004.
  1. liamjf
    liamjf
    Dec 20, 2002
    310
    LONDON
    +9
    Hello chaps, title says it all really, looking for a sub to add to my AV system and to add aliitle lower end butchness to stereo as well .
    Here's the thing, must be in wood finish (don't care what) for WAF and have dual inputs and gains in order to produce trouser wobbling stuff for the new STAR WARS DVDS and also something a bit more subtle for stereo. Second hand no problem so what would you suggest? So far looked at REL Strata III and BK-XLS 200 and even MJA Ref 100 (maybe a bit too small) but haven't heard anything. Cheers for any advice,
    Liam.
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Its a shame that you cant get WAF for black or non wood finnish as the new baby SVS would come in under your budget and give nay thing else in the £400 bracket a serious run for its money:gri:
    http://www.svsubwoofers.com/subs_pb10_isd.htm
  3. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,349
    Livingston, Scotland
    +227
    Liam
    You could probably pick-up a REL Quake in Cherry for £400. It works well for both movies and music, but will get lost in a larg(ish) room
  4. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    You could ask in the classifieds to see if anyone is selling a B&W ASW675, if you are willing to go 2nd hand, you could find what you are looking for.
    If you up your budget a little, the Mordaunt Short MS909 could also be an option, or a KEF PSW3000.
    If you can get round the WAF factor, then it opens your doors to the SVS mentioned above, or a Servo 15 if you can find one in the classifieds.
    It might also be worth looking at the Mordaunt Short MS409, not a wood finish, but still very WAF in it's silver finish. I believe AVLand.co.uk sell the MS409 sub seperate to the rest of the Genie package.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    You may just about sneak in a second hand REL Storm 3 in wood finish at £400 which has everything that you have asked for - and more
  6. liamjf
    liamjf
    Dec 20, 2002
    310
    LONDON
    +9
    Thanks for that Ian - I'm looking. :) As for the others - are any of them actually suitable for my requirements? i.e. wood finish and simultaneous high and low inputs?
    Liam.
  7. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I'm not sure about the B&W ASW675 as most B&W subs don't have high level connections. You have to be careful with some of the others as whilst they may have both types of connection they may only have one set of controls which renders it useless for your purposes.
    REL's definately fit the bill and speaking as an ex Storm owner that one fits the bill very well indeed
  8. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    The ASW675 does not have Hi (Speaker Inputs) just lo (line Level) but it is a fantastic sub, why do you need both, do you have two setups?
  9. Philly112
    Philly112
    Oct 17, 2003
    4,321
    Frodsham
    +1,670
    I 'may' be selling my Cherry Rel Storm 3 in the not too distant future. Have just bought a 2nd hand M&K MX150 off the classifieds, and either that or the Storm will go! (why would I sell what I have just bought?? - WAF of course! ''what the :censored: is that?'' was the response at 5:30pm today)
    Phil
    PS The Storm has high and low inputs, as I believe do most Rel subs.
  10. liamjf
    liamjf
    Dec 20, 2002
    310
    LONDON
    +9
    Yeah 2 channel setup via Primare amp and high level, 5 channel via Marantz and low level. Must be able to use both simultaneously with dual volume controls for seamless integration with 2 channel and whack it up to full sod the hi-fidelity for dvd watching!
  11. moviemike
    moviemike
    Aug 10, 2004
    94
    Swindon
    Anybody got an opinion on the MJ REF 100? Been thinking about one of them for my basement?
