£400-500 to spend ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by spocktra, Apr 26, 2005.
  1. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Have a list of possibles for this price bracket,has anyone got any comments good or bad.I dont need hdmi or dvi,divx.Its purely a movie machine via component.Not bothered about cd replay either. Toshiba sd-9500 ,arcam dv88/88+,denon 2800/2900. I appreciate that i may have to buy used on some of these but that is fine.
  2. geoxen
    geoxen
    Have you looked for any Pioneers?
  3. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Not considered pioneers because their high end players usually come with hdmi which i dont need.Correct me if i am wrong.
  4. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,687
    oxfordshire
    +348
    pioneer 757 doesnt have hdmi
  5. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Is the 757 pio going to outperform my current toshiba 340e and more importantly any of the players i mentioned earlier.
  6. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,687
    oxfordshire
    +348
    I have just upgraded from a pioneer 575 to a pioneer 757ai, i would say the 575 is equal to your 340e in pq, the 757 wipes the floor with the pioneer 575, so should out perform yours easily,Sound quality with cd is a lot better to.
  7. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Thanks for the comments,might check out the pioneer but i like the sound of the tosh sd9500.
  8. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Stunning machine visually & sonically (CD & DVD-V/A) Spocktra. £400 its a no-brainer TBH.
  9. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Is the 9500 now shipped with prog scan firmware?
  10. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    http://www.avforums.com/forums/showthread.php?t=56705
    Worth reading this thread from start to finish Spocktra, the units sold "end of line" by Toshiba at xmas times (which many forum members bought) were actually prog scan enabled, even though Toshiba said they would not be. Only problem seems to be getting them MR. Saying that though, this machine is so superlative in everything it does - Ive forgone MR, I use my old DVD for that.
  11. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Cheers for your insight. :)
