< £40 2.1 sound system for my PC
Discussion in 'Home Cinema Speakers' started by diddums100, Apr 23, 2003.
  1. diddums100
    diddums100
    Apr 23, 2003
    142
    Trowvegas
    +3
    I'm just looking at getting some new desktop speakers for my PC and was interested in getting something a little better for my money than a £10 job so thought i'd spend a little more.. well.. i've looked at the logitech and creative offerings (the Creative Inspire 2.1 2400, and Logitech Z-340 2.1 Speakers) and was wondering if anyone could give me a nudge in the right direction as to which one was better.. OR if there is a speaker set i've missed which would be better? thanks for your help (in advance :D).
    B@Th*nG
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,477
    71
    Newcastle
    +81
    This months PC Pro is doing a test on several speakers. I would buy a copy and see for yourself.
    This post may be better in the HTPC section of the forum
  3. Howard0000
    Howard0000
    Jan 11, 2003
    938
    28
    Surrey
    +28
    The Logitechs I've been told are better than the cheaper Inspire systems, but the more expensive ones (i.e the 2800s) are meant to be good aparently.
    The Z340s can be had for £38 from Here
  4. alextgreen
    alextgreen
    Apr 17, 2001
    545
    London
    +5
    Inspire is alright, it's the cheap setup I use at uni (mine is FAR too big for a dorm room). Take a while to break in, once there they are a bit harsh, the sound is very clinical. Subwoofer spits, pops and crackles at all but a whimper above minimum but that's honestly all it needs to balance the sound. Tis OK for 34 quid I suppose, sounds a lot better than cheaparsed hifi systems.
  5. diddums100
    diddums100
    Apr 23, 2003
    142
    Trowvegas
    +3
    hmm.. i may side with the Logitech 1's purely because i've heard pretty much just good things about them... i've heard that they dont do high pitch sounds too well.. but i only use them for games and music so it shouldn't be that much of a problem. The creatives dont have a headphone jack as well which WILL get irritating cos i play CS with headphones on. That's for all your help.. if ne1 has nething else 2 add then it's much apprechiated!
    B@Th*nG
  6. avanzato
    avanzato
    Jan 21, 2003
    1,874
    Norfolk
    +60
    How about the S40 in the TDK tremor series Simply have them at £27 + postage.
    The sats look the same as the ones from the S60 in which case they sound nice, money seems to have been saved by using a smaller sub.
