£3000 Budget
Discussion in 'Projectors, Screens & Video Processors' started by marshy.dave, Aug 18, 2005.
  1. marshy.dave
    marshy.dave
    All,
    The time has come for me to upgrade from my trusty 42" Hitachi Plasma (Will be mnoved to another room) to a projector setup.
    I have 3k budget and am looking for the best I can get for my money. This is just to include the projector and the screen.
    I have a 22ft long by 15ft rectangle room. The screen witll be going at one end in front of a window that is covered by curtains. Ideally I would like as big as screen as I can get, was hoping for 8ft in 16:9 format.
    The projector will either be about 12ft to 15ft away if on the coffeee table or 18ft to 21ft if at the back of the room.
    I have been looking at the Sony VPL-HS50.
    No idea yet about the screen
    Thoughts anyone
  2. Zag
    Zag
    Jun 29, 2004
    916
    Poole
    +47
    £3000 to spend. No sensitivity to rainbows. New Optoma H79 a no brainer.
  3. n0s
    n0s
    Jun 11, 2005
    173
    16
    Istanbul
    yeah but at 3000 he wont get a H79 plus an 8ft screen even if it is a manual as opposed to electric...
    so if i were you i would wait, work a little harder get some more cash together and get the H79 and a decent Electric screen and voila your onto a winner...
  4. marshy.dave
    marshy.dave
    Thanks, so can you recommend a good quality screen
  5. Zag
    Zag
    Jun 29, 2004
    916
    Poole
    +47
    Saw this the other day. I can't vouch for it's quality but I thought it was well priced for a electric tab tensioned screen.
    http://www.shootandshow.co.uk/nexnix_projection_screens/nexnix_tab_screens.htm
    nOs you are right £3000 won't get a PJ and screen. My fault didn't read to the end of the paragraph.
    However there are places that will do an electric 8ft screen at half price (£399) with the H79. I'm not too far out. ;)
    As for a screen recommend all I can vouch for is Carada because that's what I've got. Unfortunately they only do fixed frame screens as far as I am aware.
