£300 which sub to match these?
Discussion in 'Subwoofers' started by Adrenochrome, Feb 12, 2003.
  1. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,035
    Babel Sensurround
    +207
    tannoy mxc-m centre
    tannoy mxc-2 rears
    tannoy mxc-3 fronts
    i am going to tie this to a yammy rxv630rds and tosh sd220e
    does anyone know if these speakers are any good for hc?
    regards
    Tom Barr.
  2. eddiea
    eddiea
    If you already have the speakers why not try them, if not borrow some from a dealer.
    As for the sub you won't go wrong with a Velodyne CHT-10 @ £325 from uncle eric in the power buys.
  3. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,035
    Babel Sensurround
    +207
    i don't have the speakers yet
    i think i would be hard pushed to find a dealer willing to let me borrow some in central scotland
    do you know if they sound good for movies?
    regards
    Tom Barr.
  4. eddiea
    eddiea
    Tom
    Sorry I dont know how they sound, you could try a search of these forums or the net.
  5. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Tom, just a thought but if you are going for a decent sub like the Velodyne CHT10 (to take care of the low stuff) then there's arguably no need to go for big floorstanders like the MX3-M's. You might as well save some money and get the MXC-M plus either four MX1-M's or two MX1-M's a two MXR-M's.
    All you would then need to do is set all the speakers to "small" so that the sub takes care of all frequencies below a given Hz (usually something like 90Hz on Yamahas).
    Having heard an M3, MC, M1 set up many years ago, I would expect the latest M series Tannoys to sound perfectly good for home cinema.
    Matt.
  6. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,035
    Babel Sensurround
    +207
    what about the tannoy rsub 15 would this be better than the velodyne both in performance and matching??
    regards
    Tom Barr.
  7. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Tom - because of the frequency range in question (80Hz and below) there is no tonal matching to take account of with subs - you should be able to match up a decent sub with speakers from any manufacturer.
    I'm not familiar with the performance of the Tannoy R 15 but it does look like quite a beast. Have a listen to one by all means.
    Matt.
  8. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,035
    Babel Sensurround
    +207
    thanks for the help folks
    Tom Barr.
