£300 sub
Discussion in 'Subwoofers' started by scrapbook, Nov 5, 2004.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,422
    +550
    I have finally go to the stage where the only thing I have left to upgrade from my original all in one system is my sub.
    I have two main requirements other than the obvious that it has be a good one! It has to be
    - reasonably compact
    - available in silver
    The three I have found that seem to meet my needs are:
    - MS409
    - MJ Reference 100
    - REL Quake
    I think that the BK XLS200 is too deep for the space allocated for it in the living room by 'er in doors :mad: !
    Does anyone have anythoughs on the best of those three or can recommend anything similar?
  2. recruit
    recruit
    Hi Scrapbook alot of people seem to give the MS range of subs the thumbs up the Rel is alittle too polite for my likeing but can't comment on the MJ subs as never heard any.
    John
  3. BK Electronics
    BK Electronics
    Active Member AVForums Sponsor
    Aug 10, 2002
    376
    Essex
    +25
  4. scrapbook
    scrapbook
    Jan 12, 2002
    7,422
    +550
    Thanks for remembering me Tom!
    I have another question for you though if I may. I was reading the thread on the budget sub test again and it seemed to indicate the sub wasn't shielded and there was some interference with a TV. Is that the case?
  5. BK Electronics
    BK Electronics
    Aug 10, 2002
    376
    Essex
    +25
    Hi Alan
    The XLS200 uses a peerless XLS10 drive unit that is NOT shielded, although it has a double magnet system that reduces the magnetic field there is still enough of a magnetic field to disrupt a CRT, if you get the sub too close to a TV. Now how close is close?. My monitor at work sits on a bench 75 cm's above the floor and I can put an XLS200 directly under the monitor without a problem so I guess you would need to keep the sub about a 1 metre from the TV.
    Hope this is of help
    Tom
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    The BK only really caused TV problems when it was stacked on another sub, ie. at screen level. Certainly best to keep a metre or so away as Tom said.
  7. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    My BK sub is directly to the right of the TV on the floor (the centre is about 60cm from the bottom RH corner of the screen) and it doesn't interfere with the picture, AFAICT. It's off-axis though, which I imagine might help things.
    BTW, love the new version. :smoke:
  8. moby78
    moby78
    Oct 4, 2004
    24
    4
    Birmingham
    I originally put my BK around 50cm behind one of the corners of my TV and there was a slight bending of electrons causing some discolouration. Its now around 70cm away and there are no problems.
    FYI my TV is sitting on an Apollo stand just above the height of the sub.
  9. belgrade
    belgrade
    Mar 4, 2004
    137
    16
    newcastle
    Tom,
    I'm unsure as to which one of the xls200 models to go for, down-firing or forward?
    If the performance, bass quality etc is the same from either design, then what criteria should be used in choosing one over the other, or is it just a case of choose the one which looks better to me?
    What about positioning, room surfaces, flooring, room size? Should they influence my choice.
    For reference, my room is 5m long by 4m wide by 3 m high with wooden flooring (on top of floorboards).
    Because the sub cannot go within a metre of the TV, there is only really one place it can go, the front left corner.
    Does this info suggest to you that I should be leaning towards one of the designs over the other, with respect to getting the most out of the sub given the characteristics of the room.
    Btw Tom, the picture of the down-firing version on the website - is that light oak or cherry? And how long would it take to get the sub (either version) if I ordered today?
  10. Dean
    Dean
    Jun 20, 2003
    2,891
    London
    +264
    I'd gp for the downward firing one as i've heard this design is usually better than forward firing in the way the bass interacts with the floor. Also downward firing looks a lot better IMO.
  11. BK Electronics
    BK Electronics
    Aug 10, 2002
    376
    Essex
    +25
    Hi Belgrade
    The XLS200-DF on the website is a cherry veneer, if you look at theh forward firing one in light oak http://www.bkelec.com/new/Special_Offers/Light_Oak.htm this will give you some idea of the finish. Light Oak is available from stock and Cherry early next week.
    If you need further help please could you email me tom@bkelec.com
    Tom
  12. whats_this
    whats_this
    Dec 26, 2003
    504
    +11
    im actually just about to sell my rel quake but is black but gonna be a complete bargain at about 200 quid just in case you wanna save some cash. sorry to hijack the thread but just thought you might be interested.
