£300-£400 Subwoofer Recommendation
Discussion in 'Subwoofers' started by Buckster, Nov 26, 2003.
  1. Buckster
    Buckster
    May 21, 2001
    7,004
    103
    UK
    +358
    I'm looking for a Subwoofer upgrade and was wondering whether the forums can point me in the right direction. I currently have a Yamaha SW-90 which is OK - but tends to produce Bass rather than "Sub-bass" if you get what I mean -so I'm tempted with an upgrade. I'm not particulary looking for loudness as I tend to keep the volume down because of my neighbours - but looking for that real low down sub movie effect.
    I can pay up to around 400 pounds - and would prefer a bottom firing sub as I've found the front firing Yamaha really sensitive (location wise) for setting up (you can move the angle 3 degrees and bass sounds completely different)
    Unfortuantely 400 pounds from looking on the net seems to be in sort of no-mans Sub land - lots of subs at around 150-200 pounds and 600-1000 but not much in between.
    Just was wondering what people could recommend ? I'm thinking I'm best waiting to see what comes up on the forums and elsewhere 2nd hand - but what would people recommend brand new ?
    Many thanks for any help - my system is as below:
    Mark.
    Yamaha DSP-A5
    NAD C-350
    Pioneer 656
    Tannoy RC Centre
    Tannoy M3 Fronts
    Mission 731i Rears
  2. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    when i was at work the other day i asked if they had any more paradigm pw2200 in, as i am thinking of getting a second after i purchace my projecter. If you nip into your local RicherS and ask them to check the computer they should have 8 and they should be able to transfer it to u. about £300-350. well worth the money, nealy as good as the servo 15(in some respects better) and if you dont know how good that is do a search- servo15-
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,502
    Edinburgh
    +1,237
    MJ Acoustics Reference 100 for £350.
    [​IMG]
  4. Buckster
    Buckster
    May 21, 2001
    7,004
    103
    UK
    +358
    Thanks for the tip - I'll look up some more info on that sub.
    cheers,
    Mark.
  5. monkeyboy69
    monkeyboy69
    Mar 30, 2002
    589
    +11
    I've also been looking at something in this price to replace my pdr10, I was thinking along the velodyne cht series if thats any use to you
  6. Buckster
    Buckster
    May 21, 2001
    7,004
    103
    UK
    +358
    clancol
    Which is your local store ? I tried Richersounds - Middlesborough - and they didn't have any ?
    Thanks,
    Mark.
  7. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    clancol
    I called Glasgow RS today only to be told that they don't sell Paradigm products anymore.
    I had called about the Servo 15 when it was £399 in What Hi-Fi and was told they'd have one for me in two weeks so after two weeks i called and was told it would be in the next day but when i called just to make sure it was in the shop i was told they didn't have any at the warehouse but would definately get me one when another shipment arrived - still waiting 2 months later.
  8. Buckster
    Buckster
    May 21, 2001
    7,004
    103
    UK
    +358
    JIT,
    They offered me an alternative a Mordaunt Short something .... not sure what was 500 quid.
    Perhaps they weren't selling any of their own-brand stuff in enough volume because the Paradigm are so good - and were loosing out on profit.
    Mark.
  9. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    They offered my a Tannoy Revolution Sub for £399, i have Tannoy R3's and a PS1000 at the moment but looking for a significant improvement in the sub department.
  10. Buckster
    Buckster
    May 21, 2001
    7,004
    103
    UK
    +358
    They offered me the Tannoy RSUB15 too - but for 349.99 - can't find many reviews of it but from forums seems Tannoy aren't good for Subs - although the RSBU15 is quite a beast.
    Mark.
  11. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    I didn't realise how right you were about your price range being a sub no-mans land until I started looking around.
    If you insist on a downward firing sub it would seem that MJ Acoustics Ref 100 is the best on offer and a good sub it is indeed which should give you everything you are looking for.
  12. Buckster
    Buckster
    May 21, 2001
    7,004
    103
    UK
    +358
    The MJAcoustics does look pretty good - but can a 8inch driver really deliver that low bass I'm looking for ?
    I don't have to go for a bottom firing sub - its just I found my front firing Yamaha hard to set-up but it may have just been a trait of the Yamaha.
    Cheers for all your responses by the way.
    Mark.
  13. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    You are probably correct that it may be a trait of the Yamaha and not front firers in general.
    Have a look at the Velodyne CHT-10. Forum sponsors AV-Sales.com are authorized Velodyne dealers and tend to look kindly on forum members pricewise.
  14. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,502
    Edinburgh
    +1,237
    Don't be put off by the small size of the MJ sub. Book a demo of one at your local dealer and prepare to be amazed.
  15. AndersR
    AndersR
    you should definetely check out the new sony s-master 1000W 36kg! SONY SA-WX900 :
    http://www.avland.co.uk/sony/sawx900/index.htm
    it seems the price has fallen to almost half the retail price very fast. I think it's cheaper than in the US! The specs comepares to the YAMAHA YST-SW1500 which costs 600£.
    I hope this helps
    please let us know if you do a demo.
  16. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    If you're looking to go down below mid 20;s Hz then the answer is almost certainly "No".
    Nice subs and I've nothing aganist them but a small box with an 8" driver and a 50 or 100 watt amp is going to have it's limits depth wise - in fact it would be unreasonable to expect anything else.
    There are some tiny subs that can go really deep e.g. flat to 20Hz with no room loading - the Velodyne HGS10 springs to mind - but these use huge amps and cost serious money (£1500 plus).
    Matt.
