£30 Pci Adsl Modems
Discussion in 'Desktop & Laptop Computers Forum' started by 50/50, Jun 6, 2003.
  1. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    Anyone got one of the £30 adsl modems ?
    Im abit sceptical about anything that is cheap.
    Is there any lag ?
    anything that i should know about before I finally dumb ntls rip off 128k service and go with adsl ?
  2. mwltuk
    mwltuk
    Don't know if you've done anything yet but if you haven't...
    Go for an external DLink Router. I have a DSL-504. You can get one for about £80. It has NAT giving you a firewall and 4 ports so you can home network and allow other PCs to access the net without using MS ICS. It's also very fast!
  3. Pootle
    Pootle
    Apr 14, 2002
    149
    Staffordshire
    I'll second that; the cheapo PCI cards are effectively winmodems - which means they use processor power to drive ADSL at a fairly low level; experiences I have seen suggest that a 1Ghz processor playing games like counterstrike will give approx 1/2 the frame rate with USB or PCI ADSL thingy compared to external router (and you can get a firewall in there as well these days!)
    See adslguide
