£2k - what to dem?
Discussion in 'Home Cinema Speakers' started by RobDickinson, Sep 6, 2001.
  1. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,745
    Christchurch , New Zealand
    +736
    The only problem with the monitor audios is that I dont think i'll get em past my SO - she soent like their looks...
    Cant say their top of my list in that department either.
    She prefers the looks of the 782s - me I like the CM4's - their sound too.
    Its just that they havnt got the best reviews & most shop dealers get that glazed look when you mention them and quickly point me to some proaks....
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,871
    2
    167
    Birmingham, UK
    +9,616
    You should consider auditioning Ruark speakers which got some great reviews recently.
  3. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,745
    +736
    Sometime next year (I know - cant wait though) I'll be replacing my HC speakers.
    What I have now :<br />gale Model 4's - mains.<br />JBL mr center (eeeeek...)<br />Kef Coda 7 rears.<br />kef 20B sub.
    I'm keeping the Sub & possibly the rears in a 5mx4m room - I want good movies BUT 2/5 channel music is a priority.
    I'll be demoing (as mains) :<br />B&W CM4's<br />Mission 782's<br />Monitor Audio 8i's<br />Proak studio 125's<br />kefs (reference one-two's plus some Q series ones).
    <br />Any others I should consider?<br />Athetics are important too - no big uglies please (thats dynaudio etc) the SO wont have it...
    Kit it'll be pluged into (short term - some of this'll change).<br />Pioneed PD703 CD<br />Panasonic A350 DVD<br />Yamaha E493.<br />Kenwood ka3020Se.
    <br />Cheers...
  4. le hutch
    le hutch
    Ive got Monitor Audio 9i (paid £600 ex demo <img src="biggrin.gif" border="0"> ), monitor audio 12i center and fxi bipolar rears. very very happy with them.
    They can sound a little bright, so be careful what you hook them up to. I have arcam kit.
    Also they need a lot of running in because of the C-Cam cones.....
  5. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    What amp are you actually using?
    I would go for the ProAcs, also see if you can find a dealer which carries Focus Audio - Canadian made and sound fab.
    The Dynaudio Audience series is indeed ugly, but the Countour series - now that would be something.<br />Unfortunately they are not anywhere near cheap and need some beefy amp to drive them.
  6. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,745
    +736
    Amp wise I'm not sure yet.
    Budget for the amp will be about £1k.
    Possibly just add a Rotel1075 to the Yamaha e492 or Rotel Rsx972
    Either that or whatever Denon/Arcam etc have for the price thats musical.
    Either that or I'll just replace my Kenwood ka3020 with a 2channel power amp & still use my DVD/yamaha as a preamp system.
  7. Lowrider
    Lowrider
    Try the CM2 all arround + CMC + a good subwoofer, if it is well set-up you will hardly notice any difference from the CM4.
    This applies to any brand. Don´t show the Sonus Faber speakers to your wife, or you will have to buy them, then it is no problem, they sound as good as they look <img src="graemlins/evil.gif" border="0" alt="[Evil]" />
