£2500-£3000 to spend
Discussion in 'Plasma TVs' started by petrolhead, Jul 17, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,495
    71
    Newcastle
    +83
    My friend is after a Plasma and had a budget of £2500-3000
    Anys suggestions as to what he should buy.
    He will be watching his digi box and dvds.
  2. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    5th or 6th generation 42" Panasonic, or one of the 42" Hitachi panels would be the best bet.
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,495
    71
    Newcastle
    +83
    Any actual model/s you had in mind?
  4. tbrar
    tbrar
    May 31, 2003
    609
    16
    Petrolhead,
    Given the funds I think that you should look at the Panasonic TH-42PWD5, or the latest TH-42PWD6, both progressive displaying plasma's.
    The latter being slightly more cash, but on paper is fairly impressive in the Video stakes (over 1 Billion in colour range, claimed contrast ratio 4000:1) you may have to hunt around to fit within £3k.
    The TH-42PWD6 also gives you the ability to utilise DVI HDCP connectivity - should you wish.
    Tony
  5. RossC
    RossC
    Feb 13, 2003
    144
    There's also the NEC 42VP4 which can be found under £3K and has great connectivity and very good picture from what I saw at a recent demo.
  6. Dutch
    Dutch
    Dec 5, 2002
    2,594
    3
    North Yorkshire
    +281
    Hi petrolhead,
    How about the Fujitsu P42VHA20 which uses Panasonic glass? It appears to be the favoured 42" plasma on the US avsforum. Unfortunately, it's just outside your friend's budget at £3200. He would have to stretch to £3500 to get a HD capable plasma like a Pioneer 433MXE.
    Steve
  7. bluebear
    bluebear
    petrolhead,
    Nice web site M8.
    Get a 4, 5 or 6 generation 42" Panasonic, and you won't regret it.
    Take a look at AV-Sales, they giving them away TH-42PWD5 at £2560 ! or even the new super TH-42PWD6 at £3065 + input board.
    I would go for a D6 if I was choosing one right now.
    I got my D4 for £3100, and its worth every penny...
    Bluebear.
    :clap:
  8. F1ash
    F1ash
    Jun 12, 2003
    109
    Sussex
    For 3K you can get an Hitachi 42PD3000E with AV/tuner box.
    Mine produces staggeringly good pictures on DVD and Sky. Absolutely chuffed with my purchase.
  9. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    i would go for either the fujitsu or the new panasonic i couldnt live
    with the flicker on the 5th gen pannie but saying that who am i to talk because im still undecided (bit worried about buying a low res unit :confused: :confused: )
    jason
  10. JH4
    JH4
    May 6, 2003
    2,310
    63
    +225
    My vote goes to the Hitachi PMA400E, rather than the 3000E, although both are VG:
    1. No tuner - so cheaper - than the 3000E
    2. Picture in picture/split screen mode. Not on the 3000E.
    3. Hi Definition compatable. Not on the 3000E.
    4. 4 inputs of which 3 can be component. The other "S" or composite.
    5. Lovely PQ and contrast.
    6. No duff pixels.
    7. Fan noise not significant at normal watching distance.
    8. Excellent price. (But be aware the extra price of a stand.)
    Hope this helps.
    Regards
  11. petrolhead
    petrolhead
    Mar 29, 2002
    4,495
    71
    Newcastle
    +83
    Thanks for your help he has gone for the Hitachi PMA400
    Now he needs a bracket
