£250 spend for an all in one, which one?
Discussion in 'Home Cinema Buying & Building' started by twe, Sep 16, 2007.
  1. twe
    twe
    Jan 7, 2007
    220
    +6
    Hi guys...
    I have purchased the Samsung HT-TX35R but will all of the faults I am sending it back and thinking of a refund since the lip-syncing issues via optical seem common in the other thread.... and the subwoofer seems cheaply made, not enough weight on it....
    What can I purchase instead? Was looking at Amazon they have the Sony DAV-DZ630 and the Sony HTSF1100 [slightly over in price but can stretch my budget]....
    I want a unit that plays divx/xvid, has a usb port, optical in and sounds good....
    edit: would also like all 4 floor standing speakers.....
  2. m&s
    m&s
    Sep 12, 2007
    15
    3
    Hi there.
    I'm in a similar situation....... but have decided to go for an all in one without dvd player. The HTSF1100 which you have listed is such (does not have a dvd player).
    Apart from the other sony system, you may want to consider the panny systems. I understand that the Panny 850 (with 4 tall boys can be had for under £280) just over your budget, but unfortunately does not play divX.
