£2000 to spend on av and speakers help please
Discussion in 'AV Receivers & Amplifiers' started by lee3272, Dec 29, 2004.
  1. lee3272
    lee3272
    Dec 29, 2004
    125
    Grimsby
    +8
    Hi guys sorry you must have been asked this quite a few times can someone give me some options second hand or new ect ive read quite alot of threads and now im even more confused im not to bothered about music want good sound for dvd ect not sure how much to spend more on av or speakers then i need cables ect all i can say i need a toslink for xbox and a coax for digital box must admit my freind spent £1000 on a panasonic amp and keff 2005 eggs and it sounds quite good for a £1000 would i notice better sound if i spent £2000 any help on which av and speakers would be great cheers in advance
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,809
    London
    +1,082
    Welcome to the forums :thumbsup:
    What kind of speakers are you looking for, sub/sats or floorstanders?
    Plus, how important is performance music-wise to you?
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Spend the majority on the speakers. I feel if you wanted better sound spending £2000 could sound better then £1000.
  4. lee3272
    lee3272
    Dec 29, 2004
    125
    Grimsby
    +8
    Thanks for the replys im not to bothered about music as for which speakers the tvs in a corner so i guess big floorstanders are out
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,809
    London
    +1,082
    How about the Castle Compact CC3's which retail for £1k and Denon 2805 which sells for around £550?
  6. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    £2000 is a lot of dough :) the advice already given on the speaker/amp ratio is a good advice.
    My spend would probably go along these lines:
    Marantz SR7400 (£399 from Peter Tyson) http://www.petertyson.co.uk
    Quad 12L (fronts) £500 http://www.avland.co.uk/quad/12l/index.htm
    Quad 11L (rears) £379 http://www.avland.co.uk/quad/11l/index.htm
    Quad L Centre £350 http://www.avland.co.uk/quad/lcentre/index.htm
    MJ Acoustics Ref 200 sub (£650) http://www.hifibitz.co.uk/product.asp?id=3781
    This comes to a total of £2278, BUT, if you buy all of this from one dealer, and show him the £2000, I'm sure you could haggle to that price point. If not, then the extra £280 would be well spent :). If you want to compromise, you could use 11L's on the fronts as well, and go for a lower priced sub such as the Mordaunt Short MS909, or the Velodyne CHT 12R. Another sub option would be to import an SVS, the PB10 at about £380 all inclusive would be a good buy :)
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,809
    London
    +1,082
    When I was pondering on purchasing the Quads, AV Land said they'd knock 15% off the price of the package :smashin:
  8. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
