£2000 Budget Which Plasma !!! Help !!!!
Discussion in 'Plasma TVs Forum' started by IanPrice, Mar 14, 2006.
  1. IanPrice
    IanPrice
    Mar 6, 2006
    160
    UK
    +4
    Hi, I am after some help please, I have got £2000 budget to spend on a plasma and I would like it for MCE and connecting it to my PC so high resolution as possible, Bit stuck as i am a new boo, anyone got any suggestions please ? I have been looking at the new Pioneeer due to be released later this year but it says it has no DVI connection ? ANy help would be appreciated ?
  2. jackal
    jackal
    I would worry about using plasma for PC. I have the new 50" pioneer and there are issues with image retention with even 'normal' TV usage. How about LCD? The Sony BRAVIA's are getting good reviews, and there are no screen burn issues with LCD. Resolution however is 768 Horizontal lines. Sharp do a 45" LCD with 1920X1080 res, but this is v.expensive (4K+). Look in the LCD and Plasma forum as Sony are bringing high res. LCD screens out soon with more reasonable pricing.
    As regards DVI connection, no problem: just buy a DVI - HDMI cable or adaptor.
