£200 for DVD with component outputs?
Discussion in 'Blu-ray & DVD Players & Recorders' started by tosh, Feb 14, 2002.
  1. tosh
    tosh
    I have just bought a Toshiba 36ZP18P with component inputs. Unfortunately my Toshiba SD100E does not have component outputs. I have £200 to upgrade to a DVD player that does. Any recommendations?
  2. Markster
    Markster
    Toshiba 210
  3. tosh
    tosh
    Thanks Markster,
    50 people have read this and I assume none disagree...
    Can anyone top £166.68 from QED?
  4. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    No-one will disagree but I am sure you didn't want to read 50 identical posts
  5. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Make sure you buy a Multi-region version. Some shops sell them for about £30 more than the non-modified versions.
  6. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    Cyberhome ADL-528, £99.00 Richer Sounds.
    Also optical and coaxial digital out and dd5.1 decoder.
  7. steev
    steev
    Oct 22, 2001
    233
    16
    Beds, UK
    Acoustic Solutions 521/551. The 551 has Dolby 5.1 and I know it does component. Multi-region/VCD/SVCD/MP3/CDR
    £80/120 at Richer Sounds
    If you want a slightly cheaper option. You can always buy movies with what you save over the Tosh, although the Tosh does get consistently good reviews.
    Steve
  8. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    After those two last recommendations, let me just re-recommend the Toshiba SD210E.
  9. bob007
    bob007
    Found this link on another thread posted by Brad123.........
    All this for under £200 ($225), will be interesting to see what the reviews say about it.........
    Nintaus DVD
  10. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    After spending all that money on a 36" Toshiba TV there is no point in saving a few quid by buying a bargain basement DVD player. The Toshiba 210 is the very least that you should be looking at.
  11. smarty
    smarty
    Feb 16, 2002
    299
    28
    Kent
    +26
    I got my Tosh 210 from Electro Centre for £179.99. Multi-region (including RCE). Picture is fantastic connected to a Tosh 40" RPTV via component. Has to be the way to go!
  12. damtom1
    damtom1
    It has to be the Toshiba...I had mine on 14 days trial from Richer Sounds.Absolutely no reason to change it,both sound and picture are very good.I upgraded my scart lead ,this also improved the performance.200 quid well spent.
  13. Aussie68
    Aussie68
    Try the Toshiba SD210E (multiregion). I got mine this week for £160 & its the best money I've ever spent.
    Toshiba SD210E Multi region DVD
    Kenwood KRFX 9050 amp/reciever
    Mission 702e front speakers
    Mission 771e rear speakers
    Mission 77C1 center speaker
  14. tosh
    tosh
    the 210 is on order, will arrive on monday
    multi region
    rce
    vcr
    199 squids from dvdmagic
    looking forward to component loveliness...
  15. telemacas
    telemacas
    Tosh SD210E £185.95 from Richer Sounds, looks good on a Sony Wega KV-28FX60 100hz
  16. tosh
    tosh
    no vcr though
  17. telemacas
    telemacas
    Who needs a vcr when picture and sound quality are miles better:D
  18. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,276
    Two pages and all you need to know is 210. This one is a no brainer, hell even your TV remote can now control the TV. It doesn't get much better than this.
  19. dyerseve
    dyerseve
    Aug 29, 2006
    19
    wow a TV remote that controls a TV - what are the chances:confused: wouldnt it be great if it also controlled his dvd player :D
  20. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    Was there any particular point in resurrecting a 5 year old thread just for that stupid joke that doesn't make sense?
  21. dyerseve
    dyerseve
    Aug 29, 2006
    19
    yes, absolutely. i wasnt trying to resurrect a 5 year old thread as i didnt realise it was 5 years old - i came across the thread while doing a search.
    ps. the joke makes plenty of sense if you read the original post that i quoted and then my post you just might get it:smashin:
