£200 alternative to E55?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Scuba Steve, Nov 23, 2004.
  1. Scuba Steve
    Scuba Steve
    Hi all
    Apologies for what, i'm sure, is about to be a foolish newbie question but if I don't ask, I won't learn!
    I am considering buying an E55 which by all acounts seems to pass the scrutiny of most of you but from what I can tell it doesn't record on RW discs. Am I newer to this than even I think or would that seem to indicate a lot of disc buying and throwing away? :confused:
    If this is the case, can anyone give me an alternative for around £200 that will allow me to re-use discs without compromising playback quality.
    Thanks in advance and apologies again for my in-excuseable lack of knowledge!
  2. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    Pioneer DVD220-S, 170 from Richer Sounds. DVD-R/-RW.
  3. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    The E55 uses DVD-Ram discs for re-writing
  4. Bosco
    Bosco
    Just so you know, Ram disks are similar to -RW disks except they will not play in any dvd player only those specially those designed to play them (all of the Panasonic range). If you plan on lending your recordings out or intend using them on another machine then the -RW would be the better option and as already recommended the Pioneer would be top of the list. If however you don't intend to lend them out and it is only for personal use then the Ram disks are perfect as they are more reliable and durable. In any event, the cost of -R write once media is so cheep now that you could afford to by a pack of 25 disks (you can get the really cheep packs for under £4), record on them once and hand out to all you friends when your finished.
  5. Scuba Steve
    Scuba Steve
    Thanks folks. Much appreciated. If the type of disc was not an issue would your recommendation be the Panny or the Pioneer?
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Panasonic without doubt: better recording quality (upto 3hrs at full resolution as opposed to 2hrs 20mins), component output and progressive scan all favour the E55 over the 220. That's not to say the 220 isn't an excellent machine though...
  7. Scuba Steve
    Scuba Steve
    Thanks Rasczak
    I have just been doind a direct comparison and the lack of progressive scan on the Pioneer had reared it's ugly head.
    The E55 order is going in now!
    Thanks again.
    Steve
  8. bluebear
    bluebear
    I just ordered mine from Dixons web site.
    Promotional Code: YOUATWORK
    For £173.83.
    If you buy something else to force the value over £200 mark, then enter Promotional Code: DIXONS20 (Only till 31/11/2004)
    Then you will £20 off orders over £200 !
    Boots were also selling them for £199, with a boots card you get £20 off and 4 free toys, all for £180...
    Regards,
    Bluebear.
  9. Scuba Steve
    Scuba Steve
    Cheers for that. Have already ordered before seeing your post but only paying £1 more from empiredirect so I think I can live with that!
