£2,500 to spend - which plasma ?
Discussion in 'Plasma TVs' started by Bone Daddy, Oct 20, 2003.
  1. Bone Daddy
    Bone Daddy
    May 1, 2001
    500
    west midlands
    +3
    A friend has in the region of £2,500 to spend on a plasma,whats the best deal or model for around that price figure ?? thanks Paul.
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Look for a series 5 Panasonic at that price in 42 inch or a series 6 37 inch,
    Neil.
  3. RossC
    RossC
    Feb 13, 2003
    144
    I'll vote for the NEC VP4S - available online for that price.
  4. Mr THX
    Mr THX
    Nov 26, 2002
    1,293
    Barnsley
    +31
    Bone Daddy
    If your friend wants to put an extra £100 to their £2500 theres a Panasonic PW6 available in Black at Techtronics
    Of coarse I'd recommend you to do a search on this Forum for 'Techtronics' just to see for yourself what other members people think;)
  5. lovegroova
    lovegroova
    Jul 15, 2002
    2,522
    103
    Herts
    +294
    The series 6 is only available as 42" (or 50"). 37" is only available as the TH37PA20B which is a plasma TV rather than a display.
    Please feel free to correct me if I'm wrong.
  6. whuuf
    whuuf
    Sep 26, 2003
    153
    16
    Essex
    I viewed the NEC VP4 alongside the panny 6 at the ideal home show and the nec compared very favourably. It also comes with very good connection inputs. Don't forget that you are going to have pay for a wall or stand mount as extra and in the case of the panny probably another couple of connection boards and your looking at £3000. The only downside of the nec is that the dvi is not HDCP. your other options are the smaller philips which comes with wall mount or the hitachi.
