New Bloke
Established Member
I was an early adopter with big screen TV's, I bought a 42" Sharp 1080p six years ago for £1,300.00 (yep they were that expensive back then!).
I am looking to change and upsize to 46/47" - 60" with a budget of a grand.
My sitting room is rectangular and the TV sits in the middle of one of the long walls. There is a window on the right hand of the TV (about 7 feet away) and there is also light from the kitchen (about 10 feet away).
I didn't go down the route of plasma before as someone said that the front is reflective and if you have a lot of light in your room, this can be a major pain in the rear end.
I will be running Sky HD, Blu-ray and Wii on the set.
A 3D set is not my top priority as I do not have the full Sky package (only movies, not sports) and the blu-ray is not 3D capable.
How about any of these ones???
46" LED - TOSHIBA 46TL963B - £570
60" LED - Samsung UE60EH6000 - £1000
60" LED - Sharp LC60LE636E - £900
50" Plasma - Panasonic Viera TX-P50UT50B - £600
60" Plasma - LG 60PA650T - £880
I'm not too concerned about power consumption, its more towards the reflective surface (would I see the picture on a sunny day or if the sun is shining on the screen. I assume with other aspects like motion blur etc, is this still an issue with LED's?
Your thoughts would be much appreciated.
