£150 to spend. Any recommendations?
Discussion in 'Home Cinema Buying & Building' started by The Duke, May 27, 2005.
  1. The Duke
    The Duke
    Looking to buy an all-in-one system, cd, tuner, tape (maybe / maybe not / unlikely?).
    Not a boogie box, as we wish to site the speakers on separate shelves.
    Anyone got some sound offereings as it's for a 14 year old girl, NOT a hifi buff!
    Tim
  2. toby151
    toby151
    Panasonic SC-PM18 ( or sa-pm18 i forget) is pretty good, its the same as one i own but without optical output. Sounds good and has 5 CD changer and bi-wired speakers. You should be able to pick it up around this price. There is also the pm19, pm20 and pm28 and 29 which you could check out as they are from the same range.
