Hi guys,
I last built a PC about 5 years ago so I am completely out of touch now and need a bit of direction, should be ok after that. I have about £1300 to spend on a new gaming rig and would like to know what direction to go i.e.
Nvidia or ATI?
Motherboard (pin set)
Intel or AMD?
Dual graphic cards or single?
Good suppliers?
Cooling?
Thanks, any help is appreciated.
Steve
hi buddy
1) nvidia/ ati i find ati to usually have the slightly more power efficent gpus compared to nvidia but there isnt really much in the brands, just look for the best graphics card from both companies in the respective price bracket.
2) motherboards, if you going with amd then the current socket is AM3 that supports DDR3 ram, and the same with the intel socket is that it supports DDR3 aswell, the i3/i5 and i think i7 run all on a 1156 socket.
3) intel/amd, intel generally perform better in games at any price point, however when your building value sysytems like me
amd provides the best bang for buck, i would use intel myself in your circumstances.
4) id personally recomend a single gpu configuration, as your essentailly getting more for your money as your not spending double on two gpus that dont always yeild a substainial increase in fps, however there are others who swear by them
5) good suppliers, there was a list floating around on here but generally scan, overlcockers, ebuyer are the ones that i have used and found to be good, however im sure others will flock to the thread with their own list of preferred merchants
6) hmmmm ive never tried it myself but i might recommend watercooling at your budget, however its always best to buy a case thats big enough to support wc anyway as then youll have more room to work and stand a better chance of hiding those pesky cables
however air cooling can yeild decent cooling and keep a quite resonably overclocked system cool while being reasonably quiet, but watercooling allows you to take your oc and noise levels to next level.
anyway hope this helps and ill try and have a poke around the internet at a couple of specs and see what i come up with.
Andrew
