£1300 max budget
Discussion in 'Plasma TVs Forum' started by OG_, Sep 14, 2005.
  1. OG_
    OG_
    Hi everyone
    Have decided to jump into the plasma scene, although i do have a limited budget as the title says.....
    For the forseable future i will only be using the tv for freeview(carnt afford sky :( ) xbox, ps2 and dvds....
    TATUNG TPT4202S - 42" Plasma with TV tuner - i have seen this partcular model which intrests me especially being for the price of £1095 delivered..
    Just wondered if anybody has any knowledge of this particular model or does you have any other suggestions..
    I am looking at purchasing within the next 2 weeks..
    many thanx in advance
  2. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    Looks like a LG Re-Badge to me, do a search on Goodmans, Techwood etc. And don't be fooled by the HD ready claim it is a SD screen and it does not have a HDMI port, Most HD content will be protected and require HDMI. Get a Panasonic PWD7 £1100 (with 3 year warranty £1050 without), get a scart to VGA converter best one is the JSTechnoligy for £125 but converters can be had from about £60 from Maplins. You will allso need a Scart switcher Play.com do a good one for £40, add a bracket or stand £50 from Ebay. A little over your budget but a much better screen than what is now a very old Rebadged screen.
  3. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    Looks like a LG Re-Badge to me, do a search on Goodmans, Techwood etc. And don't be fooled by the HD ready claim it is a SD screen and it does not have a HDMI port, Most HD content will be protected and require HDMI. Get a Panasonic PWD7 £1100 (with 3 year warranty £1050 without) from richer sounds, get a scart to VGA converter best one is the JSTechnoligy for £125 but converters can be had from about £60 from Maplins. You will allso need a Scart switcher Play.com do a good one for £40, add a bracket or stand £50 from Ebay. A little over your budget but a much better screen than what is now a very old Rebadged screen.
  4. steven w
    steven w
    Sep 13, 2000
    163
    16
    uk
    i have the smasung 42 inch hd ready plasma 4 sale for 1300 pounds
  5. OG_
    OG_
    Panasonic TH37PA50 - seen this model for £1,199 delivered..
    Good buy??
    (edited put in wrong price :oops: )
