£13/1500 for a plasma
Discussion in 'Plasma TVs Forum' started by dubledene, Mar 14, 2005.
  1. dubledene
    dubledene
    in the hunt for a plasma in the next few months and wandered into richer sounds and was imensley impressed by the pictures on their panels, and was even more impressed when i seen their prices, as im not too clued up on plasma tech i was wondering if the plasmas rs sells are any good, obviosly there not gonna be the newest model but how many people on this forum have panels which are 2/3 years old???
  2. dubledene
    dubledene
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    try a search mate £1500 buys alot of plasma these days...Brand new Panny PW7!!!
  4. Billyfergus
    Billyfergus
    Try the LG PX11. It is in the right price range and can be had from John Lewis with a free 5 year warranty for less than £500.
    It has excellent connectivity and has speakers supplied so you would not require any other boards or amp to get it up and working.
    I have one and am delighted with it.
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Have you left the 1 out, Billy? Dubledene, you need to decide if you need a TV or just a display. At your kind of budget, the LG might well make some sense as a TV. If you don't need the tuner, speakers and connections you can do better. You'd most likely need to have a reasonably up to date AV amplifier to go the display only route. If you have to buy this, and speakers too, you'll end up nearer £2k, but you would then have cracking surround sound to match your large screen.
  6. dubledene
    dubledene
    at the mo ive got a rdr gx7, mission fs1 7 .1 speakers , and a pioneer vsx d 912 ampam completly bamboozled by what boards ill need if any ideally i want a plasma with the speakers!
  7. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    NEC 42VR5 is worth a look too. Better connectivity than PW7, future proof and some think a better picture (some don't so you need to decide).
