£1000 to spend on Front L+R+Center
Discussion in 'Home Cinema Speakers' started by Hawklord, Apr 30, 2003.
  1. Hawklord
    Hawklord
    Feb 15, 2003
    3,518
    3
    Aldershot, Hampshire
    +286
    What would be a suitable replacement for my B&W speakers (in sig below) with a £1000 budget? I would be replacing the whole front sound stage and probably the back at a later date (not within this budget).
    They would have to be good alrounders for both movie and stereo playback. The b&W speakers I currently have are very good for the price u can pick them up for. Would I notice a major difference with this budget or an I likely to be replacing like for like?
    Any suggestions would be much appreciated.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,506
    2
    71
    High Wycombe, Bucks, UK
    +59
    There's no really going to be a step up here, more of a step across. If you still want to go ahead with it I'd suggest changing the front three to matching LCR600's, which will cost you £1,050 at full retail.
