£1000 to £2000 to send on a projectors any toughts
Discussion in 'Projectors, Screens & Video Processors' started by activeuk, Oct 19, 2004.
  1. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    ok guy as above will be useing it for my xbox pc dvds games etc etc waht is the image like on this now and want would be the best for the money thinkng about the ae 700 or the new sony h50
  2. cwoj
    cwoj
    the hs50 has a better spec on paper, but no ones seen it yet...might be better to wait a month or so for the z3, hs50 and panny
  3. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,147
    41
    NW London
    +17
    I suppose it really depends how much you want to spend. If it really is anything up to £2k then the HS50 is definitely worth waiting for. However if you are not hugely fussed about getting the best best picture then saving a bit on the AE700 is possibly a good idea. There is definitely (according to the specs) a difference on paper but it depends how much you really want to spend.
    Chris
  4. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    are there no pics of the hs50 in action?
  5. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    HS50 hasn't reached the market yet, should be around the end of this month. On the basis of reports of pre-production viewings, reckon it will be worth waiting to see..............
    S.
  6. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    are there any pics of the ae700 in action/
  7. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,147
    41
    NW London
    +17
    loads and loads - scroll back over the last 1/2 weeks in this LCD/DLP projector forum and youll find plenty.
  8. foghorn
    foghorn
    Mar 13, 2004
    629
    Central Scotland
    +22
    Also worth considering is the Mitsubishi HC900 and the Optoma H57, both new models and selling for sub £2000.
    Foghorn
