£100 - FullHD Gaming Monitor ( Benq , Philips or Hanns G ) Advice
tasman26
Please for advice they all cost around £100 , they all Full HD ,
I really want Philips one but its a best choise ?
Philips Brilliance C-line 226C2SB LCD TFT 21.5" Full HD Monitor
Quick Look
  • Product Description: Philips Brilliance C-line 226C2SB - LCD display - TFT - 21.5"
  • Device Type: LCD display / TFT active matrix
  • Colour: Glossy black
  • Dimensions (WxDxH): 51.5 cm x 19.8 cm x 39.9 cm - with stand
  • Weight: 3.3 kg
  • Diagonal Size: 21.5" - widescreen
  • Dot Pitch / Pixel Pitch: 0.248 mm
  • Max Resolution: 1920 x 1080 / 60 Hz
  • Video Format: 1080p (FullHD)
  • Display Positions Adjustments: Tilt
  • Colour Support: 16.7 million colours
  • Image Aspect Ratio: 16:9
  • Response Time: 2 ms
  • Image Brightness: 250 cd/m2
  • Image Contrast Ratio: 800000:1 (dynamic)
  • Digital Video Standard: Digital Visual Interface (DVI)
  • Signal Input: DVI-D, VGA
  • Compliant Standards: FCC Class B certified, CE, UL, BSMI, GOST, cUL, FCC, DDC/CI, RoHS, TCO Displays 5.0
  • Power Consumption Operational: 23 Watt
  • Environmental Standards: ENERGY STAR Qualified
cost : £108
Philips Brilliance C-line 226C2SB LCD TFT 21.5&quot.. | Ebuyer.com
BenQ G2222HDL 21.5-inch Widescreen LED Back-Light Monitor
  • Product Description: BenQ G2222HDL - LCD display - TFT - 21.5"
  • Device Type: LCD display / TFT active matrix - LED backlight
  • Dimensions (WxDxH): 51 cm x 17.5 cm x 39.3 cm
  • Weight: 3.8 kg
  • Response Time: 5 ms
  • Image Contrast Ratio: 1000:1 / 5000000:1 (dynamic)
Cost: £108
BenQ G2222HDL 21.5-inch Widescreen LED Back-Light Monitor (Full-HD, DVI-D, Glossy Black, 5ms, Vista Premium): Amazon.co.uk: Computers & Accessories
Hanns G HL225DBB - 22" Widescreen LED LCD Monitor
Display size 54,6 cm / 21.5" WIDE
* Panel Type TN TFT LCD / LED backlight
* Brightness 250 cd/m² (typ.)
* Contrast (typ.) 1000:1
* Pixel pitch 0,248(H) x 0,248(V) mm
* Resolution (H x V) 1920 x 1080 (16:9)
* Response time 5 ms (typ.)
* View angles (CR>10) H/V 170°/160°
* Display colors 16,7 Mio colors
* Display Surface Anti-Glare
* Input 1 VGA
* Input 2 DVI-D (HDCP)
* Supply AC 100~240V, 50~60Hz internal
* Consumption 28 W
* Operation Temp/Hum 5 ~ 35°C 20% ~ 85%
* Dimension (W*D*H) 515 x 375 x 45 mm
* Net weight 3,1 kg
* Tilt -5°~ 15°
* Kensington Lock ¿
* VESA mounting VESA Standard, 100mm
* On screen display EN,DE,FR,ES,IT,PT,NL,RU,SC,TC,JS,KR
* Safety CE, CB, GOST, 3C
* Emission TCO 5
* Power saving Energy Star 5.0
* Extras 1 Windows 7 compliant
* incl Accessory Cable (Power, VGA), Quick-Start-Guide, Usermanual (CD)
Cost: £99
http://www.play.com/PC/PCs/4-/18658510/Hanns-G-HL225DBB-22-inch-Widescreen-LED-LCD-Monitor/Product.html?searchtype=PCSH&searchsource=0&searchstring=Hanns+G&urlrefer=search&strefer=PCSH&searchfilters=s{Hanns+G}%2bc{420}%2b
What You think guys witch is best , just 2 of them have 2ms response
Is Philips good choise? or You would go for other one and why ?
i'd go with the philips, it has the best responce time as thats the time it takes for each pixel to go white black white or black white black, one of the two, anyway, i was going to get one, actually 3, problem is no VESA mounting so cant mounth them up off the desk on the wall or anything.
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
