£1.50 CD-WOW VOUCHER - Is The Deal Off?
Discussion in 'Shopping, Deals, Discounts & Bargains' started by njhpuk, Oct 20, 2003.
  1. njhpuk
    njhpuk
    Does the TSB Trustcard deal still work? If not, does anyone know of any other deals?
    BIG thanks
  2. stemc
    stemc
  3. njhpuk
    njhpuk
    Is it working with the £1.50 voucher? Have you got any links?
  4. soulboy
    soulboy
    Oct 20, 2003
    32
    I'm new to this forum - can someone send me the "£2.50 off
    method" via e-mail?
    Cheers,
    - Dougie (dougie.robb@digital.com)
  5. jon_gibbs
    jon_gibbs
    Same question - could someone kindly e-mail me the method of getting GBP 2.50 off at CD-Wow. Sorry if this has been posted before but I missed it!.
    Thanks,
    Jon
    jonathangibbs@rediffmail.com
  6. ochre
    ochre
    This evening I used this voucher deal to buy for £6.49 the new JAMES BOND 2 disc set DIE ANOTHER DAY.
    Thanks. Works out to be cheaper than PLAY.COM
  7. ScoobyZ
    ScoobyZ
    Sep 29, 2003
    912
    +54
    You should have done the £1 as well, I just got living daylights for £5.49 :)
  8. Herbal
    Herbal
    Is it with the 007 Spine
  9. ScoobyZ
    ScoobyZ
    Sep 29, 2003
    912
    +54
    I dont know I havent recieved it yet.
  10. THFC
    THFC
    Feb 24, 2003
    242
    Gloucester
    +5
    I have used the £2.50 method loads and it works.
    The problem now though is that sometimes the trustcard site is saying it has sent a £1.50 voucher but i never receive it
    Any mailinator temporary email addresses dont receive the codes, but they used to.
    I have set up numerous email accounts but receiving codes to multiple addresses i have set up is not working as it did
    Why - Cd Wow have caught on to this and the original (£2.50 off method) posted on here was removed at the asking of Cd Wow if im correct
    As it stands the method still works if you can get the code sent to your email address and then use the £1 off link aswell
  11. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    I've been having trouble this evening getting the codes to work.
    I've had them send me a new code for £1 off a CD and for £1.50 off a DVD.
    When I use the codes on their own, they work fine and the shopping cart subtracts the right amount.
    If I use the £1 off link, the code doesn't work :confused:
  12. LYNNSATUK
    LYNNSATUK
  13. THFC
    THFC
    Feb 24, 2003
    242
    Gloucester
    +5
    To get the £2.50 off you need to follow a certain procedure, if you have the £1.50 off code emailed to you and it works at checkout, you are half way there and can get the £2.50 off no problems by experimenting
    The original post has been removed as i said which explained the procedure but it still works guarenteed
    Just posting the details here now may result in the thread being removed as it was originally - so i have not
  14. mrbean
    mrbean
    Apr 18, 2003
    88
    Region 1 (USA)
    THFC, could you please email me the details on how to do this. Thanks
    -MrBean
  15. Doctor_AB
    Doctor_AB
    Aug 30, 2003
    2,312
    48
    Buckinghamshire
    +74
    something odd here as even without any special link die another day is still only £6.49 are you sure you are getting money off?
  16. DEO
    DEO
    HI Guys:
    "As it stands the method still works if you can get the code sent to your email address and then use the £1 off link aswell"
    I get the bit about sending a code to your email address
    BUT using the £1 off link, I cannot get that. Sorry!
    Terminator 3 for example is £11.99 regardless of which "link" I use to get to CD WOW. My voucher takes £1.50 off to get to £10.49 but people here can buy this for £8.99 or £9.49.
    HELP.
    Dave
  17. figrin_dan
    figrin_dan
    Jan 9, 2003
    1,993
    +135
    MickeyG posted the link in:
    'New £1.50 off cdwow link'
    It's currently about 4 threads down!
