W
Weirdoo
After reading the huge SCT855 thread I concluded that system was ideal. Ideal, but EOL I gave up on Panasonic and almost went for the Sony HTSF1000.
But check this SCT855 lovers
- Black
- 4 Tallboys
SC-PT850
1. Panasonic Plasma TV Matching --- HDMI & VIERA Link
2. High Quality Picture & Sound --- 1080p Up-conversion & High Power 1000W
3. Easy Set Up Sound Field by Auto Speaker Setup
Home Theater Receiver
Home Theater Mode: Total Output Power of 1000W (RMS)
Digital Amplifier
Surround Enhancer
Center Focus
Super Surround (Movie, Music)
EQ (Flat, Heavy, Clear, Soft)
4-Step Subwoofer Level Control (1, 2, 3, 4) Via Remote Control (Subwoofer Level Key)
Auto Speaker Setup for Quick and Easy Speaker Setting
RDS
Quartz-Synthesized Digital Tuning System
AV Remote Control
DVD Features
Built-in Dolby Digital & DTS Decoder
Dolby Pro Logic II
Auto Dolby Pro Logic II/ Super Surround Switching (DPL II for Disc Media /Super Surround except for Disc Media)
Dialogue Enhancer
Advanced Progressive Scan* (PAL/NTSC) (4:4:4 Signal Processing/4:3 Shrink Function/Letterbox Zoom & Shift)
* To enjoy a progressive scan picture, a TV with progressive scan capabilities must be used.
Cinema Mode
Variable Zoom
Multi-Format Playback (DVD-Audio, DVD-Video, DVD-RAM, DVD-RW1, DVD-R1, DVD-R (Dual Layer)1, +R1, +R (Double Layer)1, +RW1, SVCD, Video CD, CD, CD-R/RW 2, HighMAT (Level 2), WMA, MP33, JPEG, MPEG44 and DivX5)
* Products for the U.K. are not equipped with MPEG4 and DivX playback function.
Monitor Selector for optimum picture quality according to monitor type
108MHz/12-bit Video D/A Converter
Input/ Output
1 HDMI Terminal (VIERA Link)
1 Digital Input (Optical)
1 Scart Terminal
1 Component Video Out
USB Terminal for MP3, WMA, JPEG and MPEG4 Playback
* Products for the U.K. are not equipped with MPEG4 playback function.
Front Music Port for Portable Audio Player (M3)
1 Audio Input for AUX
Speaker System
4 Tower Speakers + 1 Center Speaker
Wall Mounting Holes
Front & Surround:
Tower Speaker (Wall-Mountable)
3-Way Placement (Floor / Shelf / Wall Mounting)
6.5cm Full range Speaker
Center:
6.5cm Full range Speaker x 2
Magnetic Shielding for Home Cinema Use
Subwoofer
16cm Woofer
Picture: http://tweakers.net/ext/f/92387b6c10bb4851a8291631aeecba6f/full.jpg
Anyone seen it yet?
- Black
- 4 Tallboys
SC-PT850
Digital Amplifier
Surround Enhancer
Center Focus
RDS
AV Remote Control
DVD Features
Dolby Pro Logic II
Dialogue Enhancer
Cinema Mode
Variable Zoom
Input/ Output
1 Scart Terminal
Speaker System
Wall Mounting Holes
Front & Surround:
Center:
Subwoofer
16cm Woofer
Anyone seen it yet?
