anobium
Established Member
Ok I have been using an indoor arial in my bedroom with mixed results for a while. At times it is fine, other times unwatchable. My question is I want to split the connection from the lead coming from the arial on the roof, without going on the roof. Can I just cut the cable atach a splitter and feed the cable into the bedroom?. I was also wondering about another arial on the wall but I think it is on the wrong side of the house does this matter?, all the other arials are facing the opposite way As what mine would. Thanks.
