We have two adsl lines, one for home and one for work to two separate adsl modems / routers. We want to extend both, currently the 'home' connection is extended via homeplug but need to extend the 'work' connection also.
Is it possible to run a totally separate homeplug network over the same house electrics ? If possible how do tell the homeplug unit which network to sync with?
Wifi doesn't have the range hence why we are using homeplugs.
