ChrisGgr
\no picture or smearing improvements?
the smearing cant fixed via fw,its a processing issue
Maybe it is already dimmed. Don't forget it is now darker outside than it was in summer, thus darker inside. Try shining a bright torch at the light sensor to see if the picture gets brighter. A lot of people have this feature turned off, but I like the way it dims when the ambient light level reduces, I think it keeps the picture quality more consistent.
John.
does the light sensor only change the backlight settings?? i got my back light set to 3..
thanks..
It doesn't matter what setting you have the backlight set at, it should still alter the picture brightness. Are you shining the torch in the correct place? The ambient light sensor is in the same place as the ir sensor.
John.
Yes thats right. It only works slowly. This means you don't really notice when it does it, but when you turn the feature off with low ambient light you do notice the change.
John.
I may be wrong but this looks like the problem I identified earlier this thread (2 pages ago). I think you're trying to get the HDMI inputs to the TV to pass the digital 5.1 signal through to the optical out on the telly. This unfortunately doesn't seem to work for DRM copy protection reasons I was told. The only was to do it is to pass the optical out directly to the AV system.
Thanks for the info,
I was wondering; could you connect the ps3 from the optical to a optical/coaxial connector and then connect to the av system. (there are two digital inputs side by side, one optical and one coaxial) - would this interfere with the optical signal?
Hi all, im new to the forum
I have just recently perchased a Sony KDL 40-X3000 from my local sony store for £1099 with a 5 year warrenty. The picture quality through the television is amazing but my only concern is when watching a blu ray (through PS3, HDMI cable) or hd dvd (through X box360 ( through HD component leads supplied by Xbox) or Sky + through scart lead (bought from Sony store), I experience a judder when a camera pans left to right or vice versa or when a object moves accross the screen and gets worse if the motion enhancer is turned on high or even stardard which is highly annoying,it is more noticable through Blu Ray/HD DVD and watching sport. I was wondering if anybody else experiences this problem as it is driving me mad.
I have had a engineer out once who changed all the settings which reduced the problem (which he noticed straight away) but over the past few days the problem has got worse
They have offered to replace the TV tomorrow but if this is a common problem with this television set I dont know whether to just take back the Tv and get a full refund as being a one off purchase I want it to work perfect without any problems when watching Blu rays/Hd DVD's or playing games expecting to experience smooth motion when being played. Is this just my TV or is this a common thing with this Tv that cant be fixed.
After reading through most of the forum pages the difference of problems between T1 and T2 seem to be extreme, I thought I would post my serial number and place of build so hopefully someone could help me with my problem!!
Serial Number -- 4605387
Place of Build -- UK
Date of Build -- 05/2008
Please Help!
Many Thanks
Alex
very good price,still though 46W4500 cheaper
Thanks Collo64. What is the point of an optical output if it can't forward digital audio info from the HDMI inputs? Certainly there is little or no chance of getting 5.1 from the internal DVB-T tuner... So this advanced output on the Sony is totally pointless
Thanks for confirming that. I haven't got cable TV so couldn't test the DVB-C - The point is wouldn't it be much more useful if the 5.1 was passed from the HDMI inputs to the Optical out as should happen in an ideal world??I´m getting 5.1 out from the internal DVB-C tuner
Please Help!
Many Thanks
Alex
