Hi guys,
I'm very pleased to tell to all of you that I solved the issue!!!
For all of you I reported it on my
blog and now I put it on this forum:
...I tryed something different: thinking about Samsung LCD TV firmware upgrade that worked well from a pen drive, I worked on it also for the player
and I DID IT!!! All you have to do is: rename the long name file with H1080A.bin, copy it to the main directory and insert it with the player turned off. Turn on the player and wait for the prompt to check if you have already the last version installed. Push play and wait. The unit will shut off automatically at the end. If you want to be sure you have upgraded your unit leave the pen drive connected and turn on the player
wait again for the prompt and read the version comparison.
I hope this procedure will help all of Samsung fans.
PS: I have still to check what is changed
I hope in divx improvements.
