I have just brought the item in the title.
My idea is to use this for sky+ and also get normal RF TV signal from the aerial on the chimney.
Would this work?
I will use both sky cables for the sat1 and sat2 and want to use the TV for the standard TV aerial.
If it will work how do i connect it? There is only 2 inputs on the back of the plate, it says sat2 input & triplexed input.
How will this work?
Plate Spec..
Screened quadplexed outlet
Ideal for Sky applications with low loss, minimal ingress and negligible module cross talk
SAT1, SAT2, TV & FM/DAB outlets
Low insertion loss
Excellent matching and isolation
Screened to EN 50083-2: >65dB to 1 GHz and >55dB to 2.2GHz
Compact screened housings
Easy cable connections and access
For 1 mm cable (PF100, H109F, QF100, etc.)
Requires 35mm mounting box
Would this work?
How will this work?
Plate Spec..
Low insertion loss
