Yamaha RXV667 - need remote code for Sony BluRay
Discussion in 'Integrated Amplifiers & Receivers' started by handsy, Mar 21, 2011.
  1. handsy
    handsy Member
    Mar 9, 2005
    283
    +8
    Hi all, my Yamaha RXV667 remote has the ability to program other remotes in to it.
    I've successfully got my TV working through it, but when I try and add my Sony Bluray (BDP-S380) as well it:
    (a) doesn't work and
    (b) seems to wipe the TV code from it too! :(
    Has anyone managed to get multiple remotes working through the Yam remote? If so, can you tell me how please.
    Can I also have a working remote code for a Sony BDP-S380 on my Yam remote.
    Ta :D
  2. mentm
    mentm Active Member
    Jun 20, 2008
    3,549
    +397
    Can't exactly remember now but you add the different codes to the different inputs eg hdmi1 or av3 etc etc. You press the button at the top to change between the amp and the source it changes colour between green and orange.
  3. handsy
    handsy Member
    Mar 9, 2005
    283
    +8
    Ah OK, that's what I was doing...perhaps I just didn't enter the right code out of the manual for Sony. There are bloomin' hundreds though! :(
  4. gidds
    gidds Member
    Nov 26, 2009
    4
    Hi handsy. Interested to know whether you found the correct code?
    I'm trying the same exercise with an older Yamaha amp.
  5. handsy
    handsy Member
    Mar 9, 2005
    283
    +8
    No sorry :(
