Yamaha rx-v367 warning 1.
Discussion in 'Integrated Amplifiers & Receivers' started by STORMIE7464, Mar 5, 2011.
  1. STORMIE7464
    STORMIE7464 Member
    Mar 5, 2011
    2
    Hi all, just bought the Yamaha rx-v367, Boston soundware 5.1 spkrs, lg 560 BD, all set up and keep getting WARNING (1) from the yamaha, ive checked all speakers again and again,
    all seems to be working and sounding very good indeed,
    any help will be welcome, also any tips on setting up home cinema as im a newbie at this stuff. cheers
  2. Foghorn Leghorn
    Foghorn Leghorn Member
    Mar 16, 2005
    10
    According to the manual (p28) you can get this error even if the speakers are connected correctly. Apparently depends on the type of speakers and the environment.
    If you're absolutely sure the speakers are wired right then ignore it. My front left and front right bring up the same error on a 567 with Bostons.
  3. STORMIE7464
    STORMIE7464 Member
    Mar 5, 2011
    2
    Thanks for the reply, all seems to be connected properly,
    the bostons are excellent, and the amp is very good considering how much it cost, my xbox360 sounds awsome, just a few refinements and all should be good
